Un'infrastruttura IT stabile è importante per le aziende di tutte le dimensioni. In qualità di partner per la trasformazione digitale, integratore di sistemi e fornitore di servizi gestiti, CANCOM offre ai propri clienti un'ampia gamma di servizi IT per conseguire il successo aziendale ottimale supportato da IT e tecnologia. CANCOM utilizza i sistemi di sigillatura Roxtec per cavi e tubi nelle proprie soluzioni di container IT modulari e nei data center room-in-room certificati da oltre 15 anni.
HVAC piping, power, data and network feeds as well as BMS connections are introduced internally and externally via Roxtec G and GH transits and, thanks to adaptable sealing modules, securely sealed against various risks starting from water, fire or gas.
Flexibility and time savings
In IT infrastructure, time is a critical and often decisive factor.
"By using Roxtec modules, a quick and clean installation of the complete solution is possible within a few hours. Thus, a quick commissioning and easy reassignment in case of changes or extensions is possible", Vice President Christian Ruscheck explains the decision for Roxtec. “The use of Roxtec modules gave us an advantage in a large number of international IT container projects in the last few years, as the systems could already be adapted and extended several times without any problems. For our end-customers and operators, the simple reassignment is an absolute added value."
CANCOM simplifies the planning of the cable and pipe seals by using the Roxtec Transit Designer™, a free software. It helps selecting the right sealing solution, configures hundreds of transits in minutes by simply importing cable lists and creates the required technical documentation as drawings and parts lists.
Why Roxtec:
- Flexibility thanks to Multidiameter™ – a solution based on sealing modules with removable layers
- Fire and smoke tightness
- Watertight
- Easy to install
- Retrofittability
Informazioni sul progetto
Descrizione del progetto
Soluzioni di container IT modulari e data center room-in-room certificati
Società coinvolte
CANCOM - proprietario
Applicazioni
Sistema di sigillatura per attraversamenti di cavi e tubi
Resistenza al fuoco, tenuta ai fumi, tenuta stagna all'acqua
Prodotti Roxtec
Passaggi Roxtec G e GH
