- Comunicato stampa
Flexible and customized seals
Roxtec round seals and Roxtec rectangular and compact cable and pipe transits are used to seal off cable ducts for low-voltage and medium-voltage cables as well as for closing off refrigeration ducts from the exterior offshore environment. Roxtec seals adapt to cables and pipes of different sizes and are in this case used for marine type power cables ranging from 4mm to 150mm and for pipes from 15mm to 25mm. Roxtec also created a customized seal to help Saitec seal flat cables.
