- Comunicato stampa
Three main needs make mobile network owner-operator Telia Norway specify Roxtec BG™ B seals: Grounding – to avoid downtime caused by the effect of lightning strikes. Protection of equipment – from fire and water. Sealing of many cables – also cables from other operators renting space.
Roxtec seals are space efficient and offer built-in spare capacity, which simplifies planning for future needs. Installers just open up seals to add cables, without adding holes or costs. The key to the future is many small sites with a maximized number of cables.
Standardized solution
All contractors use the same optimized sealing kits and the online design tool Roxtec Transit Designer™. It helps Telia document all transits and provides information to share with installers. All work can be performed without special tools or hot work permits. The shelters are sealed until it is time to route more cables.
