  3. Roxtec sealing solutions for cables and pipes protect Zurich Airport against multiple hazards
  • Comunicato stampa
Pubblicato:
The new buildings at Zurich Airport are important for the power supply and the lighting and communication systems. The owner and engineering firms were united on the choice of Roxtec sealing solutions for the cable and pipe penetrations.
Zurich Airport, the international airport of Switzerland, has added a power distribution center, a transformer station, and a substation for the slope lighting system as well as a data center to its facilities. The airport representatives and the design engineers knew Roxtec from previous projects and returned to their trusted supplier to be able to benefit from both reliable seals and dedicated support.
Tested and approved seals
The Roxtec sealing system provides certified protection against multiple risks. In this case, Zurich Airport and the engineering company specified Roxtec seals to overcome issues with water, dust, dirt, and rodents, and at the same time secure fire protection.
Flexible sealing solutions
The specific product used was the Roxtec GH transit. The transit frames in galvanized steel are bolted onto concrete walls and packed with Roxtec sealing modules that adapt to adapt to cables and pipes of different sizes thanks to a Roxtec invention.
Professional assistance
The support from Roxtec consisted of a close cooperation from planning through to construction and follow-up. Roxtec sealing experts came to the airport to train installers and verify that the work was carried out in a correct manner. All safety products must be properly installed to ensure the highest safety standards.
