  3. PR - Roxtec selected safety seal supplier by ENGIE Fabricom
  • Comunicato stampa
Pubblicato:
Aggiornato:
The challenge is to keep out the sea atmosphere. With Roxtec, you have everything under control and can be 100% sure that rooms are separated also in case of fire, says Willy Martens, Area Sales Manager of ENGIE Fabricom.
If you have a good product like Roxtec, you don't have to worry in the maintenance and warranty periods. I have not experienced any complaint for water getting into a system or into a substation, says Willy Martens.
Quality in evert detail
Partner nella protezione
