Heavy-duty pipe systems
Dissimilar metal pipe systems
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist Department Business Area Marine & Offshore at RoxtecProduct data
Find ratings, certificates and available sizes in our product database.
Roxtec SPM™ seal
Seal for metal pipes for use when welding is not allowed, recommended or desired.
Easy installation without weldingInterested in a test installation?
