  2. Application areas
  3. Sealing solutions for green fueling and charging stations
Select an experienced partner.
Investing in safe infrastructure is a must if hydrogen, electricity, and batteries are to change the basics of road transportation. New stations for fueling and charging of electric cars, buses and trucks are key in the decarbonization process. Roxtec can contribute with the sealing expertise you need – whether you are involved in modular construction, power generation and distribution or EV manufacturing.
One of the big challenges in transforming the transportation network to a fossil free environment with a healthy air quality is to ensure hydrogen and power availability in cities and along the road. It is not only a question of rapidly building new comprehensive stations or upgrading traditional gas stations. It is also important to secure all handling and distribution of the various green power technologies. New station eco-systems may combine everything from renewables, fuel cells and electrolyzers for onsite hydrogen production to batteries, BESS (battery energy storage systems), and ultra-fast EV charging dispensers.
Roxtec seals cover multiple demands
To succeed, you must use separating safety systems that protect people and spare the local grid from overload. We know how to provide seals, services, and software for cable and pipe penetrations within:
  • Green hydrogen – solar power - wind power
  • Electric vehicles – battery energy storage – power transmission and distribution
  • Modular offsite construction – advanced infrastructure projects – electrical substations and switchgear
Flexible seals for multi-hazard protection
Standardizing with Roxtec sealing solutions for cables, pipes and conduits is a way to ensure speed, efficiency, and long-term safety. The seals prevent multiple hazards, such as fire, gas, water, and the risk of explosion, and provide solutions for bonding and grounding. They are easily adaptable to cables and pipes of different sizes and available in various versions for bolting, casting, or welding to the structure.
Standardize for safety, quality and quick roll-out
Prevent the risk of a hydrogen explosion
Roxtec seals are used as a standard solution for protecting electrical equipment and scalable hydrogen facilities for water electrolysis from fire, gas, water, dust, rodents, blast load, and the risk of explosion.
Ensure stable solar power plant operation
Our penetration seals minimize the risk of downtime caused by weather or animals. The built-in spare capacity enables installers to add cables without having to cut or punch new holes in the equipment.
Keep the wind power turbines running
Roxtec provides offshore and onshore wind farms with an all-in-one solution for cable entry sealing, cable management and vibration damping. Cables are securely fixed and cable lifetime is extended.
Choose seals for large-scale e-mobility
Roxtec is a sealing partner in global e-vehicle market. We support the industry in design, manufacturing, and modernization of thermic, hybrid, electric or hydrogen buses – across continents and geographies.
Focus on reliable battery energy storage
Our seals are used in power conversion system (PCS) enclosures, battery buildings, containers, substation equipment and transformers to minimize the risk of downtime caused by fire, animals, water, and dust.
Secure power transmission and distribution
Roxtec seals protect AC and HVDC projects against water, fire, gas, rodents, and electromagnetic interference. They help you maintain optimum operating conditions for switchgear and equipment.
Simplify scalable modular offsite construction
Our flexible seals are proven perfect for modular structures and quick expansion needs. You can construct, deploy, and deliver in a streamlined, repeatable manner and still meet safety requirements.
Select tested, approved and certified solutions
Our cable and pipe transits protect against fire, gas, water, pressure, and electromagnetic threats. They withstand tough conditions and offer solutions for bonding, grounding, and hazardous (Ex) locations.
Prevent humidity and partial discharge activity
Sealing solutions must protect equipment from humidity and the frequent risk of partial discharge. Our seals prevent failure on switchgear as well as typical causes of arc and limit the effects of an arc-flash.
