Water accumulating in manholes along the track can cause costly downtime. Rodents and vibration affect sensitive equipment that may cause fatal accidents. Each year, fire causes damage worth millions of dollars. These are some of the challenges in the rail industry that call for best practices concerning cable retention and sealing. Even if no actual lasting damage occurs, the repairs will lead to downtime and project delays.
Application areas for Roxtec seals
Roxtec sealing solutions for cable, pipe and conduit penetrations are watertight to withstand climate change. The seals provide cable retention according to EN61373 to protect against vibration in exposed application areas such as overhead decks. They form a strong rodent barrier and have certificates and test results proving excellent fire protection. Click to the right to see that Roxtec UL and NFPA compliant seals are perfect for use in many different railway applications, such as traction power, trackside equipment, tunnels, bridges and railway stations.
Explore where you can benefit from Roxtec seals
Roxtec solutions help you overcome multiple sealing challenges
Roxtec R transits, Roxtec RS seals and Roxtec H seals are ideal for the rail industry. The Roxtec R is a round transit for sealing around multiple cables and pipes in a limited area while the Roxtec RS is a penetration seal for a single cable or pipe. Roxtec H is a round seal that is tailor-made for your needs.
Quick reference sizing chart
When sealing the OD of conduits, Roxtec seals can be utilized with sleeves and/or core drill openings. The charts show corresponding Roxtec seals per conduit sizes.
Conduit range | Roxtec series | Core drill size | Roxtec weld sleeve | Bolt/cast sleeve |
1/2" (.315"-1.181") |
RS50 OMD | 2" | SLRS 50 AISI316 | SLFRS 50 AISI316 |
3/4" (.315"-1.181") | RS50 OMD | 2" | SLRS 50 AISI316 | SLFRS 50 AISI316 |
1" (.945"-2.126") | RS75 OMD | 3" | SLRS 75 AISI316 | SLFRS 75 AISI316 |
1 1/2" (.945"-2.126") | RS75 OMD | 3" | SLRS 75 AISI316 | SLFRS 75 AISI316 |
2" (1.890"-2.756") | RS100 OMD | 4" | SLRS 100 AISI316 | SLFRS 100 AISI316 |
2 1/2" (2.598"-3.858") | RS125 OMD | 5" | SLRS 125 AISI316 | SLFRS 125 AISI316 |
3" (2.598"-3.858") | RS125 OMD | 5" | SLRS 125 AISI316 | SLFRS 125 AISI316 |
3 1/2" (3.661-4.685") | RS150 OMD | 6" | SLRS 150 AISI316 | SLFRS 150 AISI316 |
4" (3.661"-4.685") | RS150 OMD | 6" | SLRS 150 AISI316 | SLFRS 150 AISI316 |
5" (4.685"-5.709") | RS175 | 7" | SLRS 175 AISI316 | SLFRS 175 AISI316 |
6" (5.433"-6.693") | RS200 | 8" | SLRS 200 AISI316 | SLFRS 200 AISI316 |
RGS | ||||||||
OD | 1.315 | 1.900 | 2.375 | 2.875 | 3.500 | 4.500 | 5.563 | 6.625 |
ID Average | 1.063 | 1.624 | 2.083 | 2.489 | 3.090 | 4.050 | 5.073 | 6.093 |
PVC (40) | ||||||||
ID Average | 1.029 | 1.590 | 2.047 | 2.445 | 3.042 | 3.998 | 5.016 | 6.031 |
PVC (80) | ||||||||
ID Average | 0.936 | 1.476 | 1.913 | 2.290 | 2.864 | 3.789 | 4.768 | 5.709 |
FRE Underground | ||||||||
OD | 1.315 | 1.900 | 2.375 | 2.875 | 3.500 | 4.460 | 5.572 | 6.627 |
ID Average | 1.175 | 1.760 | 2.235 | 2.735 | 3.360 | 4.320 | 5.380 | 6.435 |
Please contact us if you would like our sealing experts to contact you for further assistance.
Ticking all boxes
Approvals
General protection
Fire protection and electrical safety
Mechanical protection
Flexibility
In the forefront
Download
Extended range for added flexibility
pdf -
Whitepaper: Roxtec BG™ - Diverting unwanted currents from your electrical installations
pdf -
Whitepaper: Cable shield bonding effectiveness
pdf -
Cable and pipe seals for rail infrastructure
pdf -
Applications for Roxtec seals in rail assets and systems
pdf
Request consultation
