Rittal Belgium supplies shelters and cabinets to Infrabel already equipped with Roxtec seals. The seals adapt to cables of different sizes and provide spare capacity. General Manager Koen Wolfcarius says:
"By offering Roxtec, you keep the flexibility for the last phase of the engineering. Roxtec seals also give perfect protection against environmental influences."
- Certified and engineered solutions
- Watertight
- Fire rated and non-toxic smoke
- Gas- and air-tight
- Corrosion and pest resistant
- Lowest total cost of ownership
Learn more about our sealing solutions for rail infrastructure.
More images
Hundreds of signaling shelters are replaced by new ones according to the European Train Control System (ETCS).
Roxtec seals form a barrier against pests and rodents and provide protection against electromagnetic interference and vibration.
