- Press release
Selected sealing solution
No need for hot work
Media contact
Roger Johansson
Executive Vice President Department Marine & Offshore Oil & Gas Business region: Karlskrona, Sweden![Roger Johansson](/optimized/contact/contentassets/20800703129346afa5da6eb2f0cc9843/roger-johansson.jpg)
