  3. Roxtec secures rail infrastructure in Belgium
  • Comunicat de presă
Publicat:
Rittal Belgium supplies shelters and cabinets to Infrabel already equipped with Roxtec seals. The seals adapt to cables of different sizes and provide spare capacity. General Manager Koen Wolfcarius says: "By offering Roxtec, you keep the flexibility for the last phase of the engineering. Roxtec seals also give perfect protection against environmental influences."
Watch a movie about Roxtec seals in Belgian rail infrastructure.
Captions:
  1. Roxtec provides complete sealing solutions for rail infrastructure and safe operations.
  2. Roxtec cable and pipe seals are tested and certified to protect against multiple risks.
