- 보도 자료
Rittal Belgium supplies shelters and cabinets to Infrabel already equipped with Roxtec seals. The seals adapt to cables of different sizes and provide spare capacity. General Manager Koen Wolfcarius says: "By offering Roxtec, you keep the flexibility for the last phase of the engineering. Roxtec seals also give perfect protection against environmental influences."
Watch a movie about Roxtec seals in Belgian rail infrastructure.
Captions:
- Roxtec provides complete sealing solutions for rail infrastructure and safe operations.
- Roxtec cable and pipe seals are tested and certified to protect against multiple risks.
