- 보도 자료
Certified protection
The Roxtec SPM seal can be used with any kind of metal pipe onboard marine or offshore structures to ensure protection against fire, gas and water. The solution makes it easy to ensure safety and operational reliability – without any downtime or cost associated with welding. The seal has a MED certification from DNV-GL and type approval certificates from ABS, RMRS and LR.
Complete transit supplier
미디어 문의
추가 정보를 원하시면 연락 주십시오.
Roger Johansson
Executive Vice President 부서 해상, 해양 유전 및 가스 비즈니스 지역: Karlskrona, Sweden![Roger Johansson](/optimized/contact/contentassets/20800703129346afa5da6eb2f0cc9843/roger-johansson.jpg)
