Heavy-duty pipe systems
Dissimilar metal pipe systems
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist Department Business Area Marine & Offshore at Roxtec![Will Hoffman](/optimized/contact/contentassets/87d3245c442f437eab317064d214ded3/will-hoffman-contact.jpg)
