A stable IT infrastructure is important for companies of all sizes. As a digital transformation partner, system integrator and managed services provider, CANCOM offers its customers a wide range of IT services to achieve optimum business success supported by IT and technology. CANCOM has been using Roxtec cable and pipe seals in its modular IT container solutions and certified room-in-room data centers for more than 15 years.
HVAC piping, power, data and network feeds as well as BMS connections are introduced internally and externally via Roxtec G and GH transits and, thanks to adaptable sealing modules, securely sealed against various risks starting from water, fire or gas.
Flexibility and time savings
In IT infrastructure, time is a critical and often decisive factor.
"By using Roxtec modules, a quick and clean installation of the complete solution is possible within a few hours. Thus, a quick commissioning and easy reassignment in case of changes or extensions is possible", Vice President Christian Ruscheck explains the decision for Roxtec. “The use of Roxtec modules gave us an advantage in a large number of international IT container projects in the last few years, as the systems could already be adapted and extended several times without any problems. For our end-customers and operators, the simple reassignment is an absolute added value."
CANCOM simplifies the planning of the cable and pipe seals by using the Roxtec Transit Designer™, a free software. It helps selecting the right sealing solution, configures hundreds of transits in minutes by simply importing cable lists and creates the required technical documentation as drawings and parts lists.
Why Roxtec:
- Flexibility thanks to Multidiameter™ – a solution based on sealing modules with removable layers
- Fire and smoke tightness
- Watertight
- Easy to install
- Retrofittability
Modular IT container solutions and certified room-in-room data centers
CANCOM - owner
Sealing of cable and pipe penetrations
Fire ratings, smoke-tight, watertight
