  2. Sealing challenges
  3. How to eliminate welding
How to eliminate welding when sealing metal pipe penetrations
Heavy-duty pipe systems
Dissimilar metal pipe systems
Transition to bulkhead unions is one of the traditional methods of sealing.
Roxtec’s alternative solution
Author
Will Hoffman
Pipe sealing specialist Department Business Area Marine & Offshore at Roxtec
Will Hoffman
Will Hoffman
Author
Will Hoffman
