No matter how great new surface ships and submarines you create, there is an easy way to make them even better. Do you know that you can simplify design and construction and at the same time optimize survivability? Just select certified seals from Roxtec. You will ensure protection against fire, gas, blast load and electromagnetic threats, and benefit from fast deliveries and outstanding technical support.
The perfect solution for the Canadian Surface Combatant (CSC) ships
Roxtec is the world-leading provider of modular-based multi-cable and pipe transits to specialized shipbuilders and perfection-demanding navies around the world. Our sealing solutions, digital tools, global and local support in Canada are appreciated by designers and construction teams as well as by owner representatives who want to secure cost-efficiency, on-time delivery, and long-term operational reliability.
Besides protecting against multiple risks, the vibration damping, the area efficiency, and the light-weight nature of the seals contribute to silent operation and free space onboard.
You can standardize with Roxtec cable and pipe transits in:
- Electrical cabinets and enclosures
- Command control rooms
- Communication areas
- Engine rooms
- Gas-tight areas
- Hydraulic and compressed air systems
- Power generators, motors and thrusters
- Water pipes
Visit our test lab in Sweden
We have extensive R&D resources, a fire test lab and material testing capabilities for use in the product development and pre-certification process as well as for the customization of sealing solutions in line with your specific needs or requirements. You are very welcome to visit the Roxtec headquarters in Karlskrona, Sweden, where you can experience our design and production facilities and for example witness a fire test. Just contact a Roxtec representative, and we will arrange a meeting or a visit.
