  3. Watertight seals for floating wind turbines
Collaborating for the future of renewables.
Flexible and customized seals
Roxtec round seals and Roxtec rectangular and compact cable and pipe transits are used to seal off cable ducts for low-voltage and medium-voltage cables as well as for closing off refrigeration ducts from the exterior offshore environment. Roxtec seals adapt to cables and pipes of different sizes and are in this case used for marine type power cables ranging from 4mm to 150mm and for pipes from 15mm to 25mm. Roxtec also created a customized sealing module to help Saitec seal flat cables.
We developed an excellent collaboration with the Roxtec team.
Aitor Sanz, Saitec Offshore Technologies
  • Watertight
  • Flexible for cables and pipes of different sizes
  • Proven offshore performance
  • Customized solutions
  • Sharing sealing expertise
Construction of floating wind turbines
Saitec Offshore Technologies – owner, design and engineering
Sealing of cable ducts and refrigeration ducts
Watertight
Roxtec RS seals, Roxtec S transits, Roxtec C KFO transits and customized Roxtec seals for flat cables
