  3. Nanhai petrochemical project
Safety and simplicity with Roxtec in the process industry
The Nanhai petrochemical project is described as the largest Chinese foreign joint-venture ever. Roxtec representatives from around the world provided help and support to the different contractors and designers throughout the project in order to simplify safety and quality work.
Safe seals throughout the plant
The plant is self-sufficient on electrical power with ten substations situated in the petrochem process areas. Roxtec seals are used in everything from the concrete walls to the cabinets. Roxtec seals are also used to seal cables entering into the inside of the process control room area. Among the demands here is protection against the risk of explosion. The combination of protection against fire, explosion, water and rodents qualified the Roxtec sealing solutions to be used wherever cables and pipes are routed from one area to the next.
Project desctiption
Petrochemical process industry
Owners
Shell Nanhai BV, CNOOC and Petrochemicals Investment Limited (CSPCL)
Engineering and main contractor
BSF – Bechtel, SINOPEC Engineering/TenthConstruction Company, Foster Wheeler Energy, Technimont, Italy and JGC, Japan
Fire protection, water-tightness, explosion-proof
