  3. PR - Poltramp Yard selects Roxtec non-weld sealing solutions
  • Comunicado à imprensa
Publicado:
Atualizado:
Certified protection
The Roxtec SPM seal can be used with any kind of metal pipe onboard marine or offshore structures to ensure protection against fire, gas and water. The solution makes it easy to ensure safety and operational reliability – without any downtime or cost associated with welding. The seal has a MED certification from DNV-GL and type approval certificates from ABS, RMRS and LR.
Complete transit supplier
Download press images
