Does your shipyard standard allow you to build ships and vessels as quickly and safely as you can and your customers want? What if you could avoid waiting for curing and eliminate some welding, and reduce the use of insulation material? There are innovative solutions that meet all requirements while enabling time and cost savings.
Roxtec multi-cable and pipe transits provide efficient solutions to everyday issues. The flexible seals enable you to avoid hot work, curing time and insulation. You can save space, manage high cable density, and add cables and pipes for new technologies and green fuels – without cutting, drilling or adding material costs. Our seals are delivered rapidly from warehouses nearby, and come with design support, technical knowhow and smart digital tools to enable easy class compliance.
Here are examples of innovative ways to seal and shield penetrations against hazards such as fire, gas, water, vibration and EMI – on the bridge, in the engine room and in areas with hydraulic pipes.
