The change to Roxtec seals in the Boston Big Dig project opened up new opportunities to solve problems such as the intrusion of water.
The Roxtec mechanical sealing system is developed to seal cables or pipes in exposed areas. Besides a very good sealing capacity, the system has been engineered to simplify installation and maintenance.
Excellent flexibility
As the contractors in Boston were looking for an alternative sealing solution, they came in contact with Roxtec.
"Due to the uniqueness of each application, it was not possible to use standard products. Roxtec worked with us to design the right solution for each application. It is the most flexible system available," says Dave Beaulieu of Mass Electric.
Stopped the leakage
With the solution from Roxtec, the installers were able to set a definitive stop to the leakage problem. Multidiameterâ„¢, the Roxtec solution based on modules with removable layers, creates the flexibility of the system. It allows every seal to be adapted on site to achieve a perfect fit for every cable or pipe.
- Easy to install in existing routing holes and ducts
- Easy to reseal after maintenance
- Spare capacity for additional cables
- Local support and customized solutions
Construction of tunnel in Boston, MA, USA
Owner
Massachusetts Turnpike Authority, City of Boston
Engineering and installation
Bechtel and Mass Electric
Water-proof sealing of cables and fiber optic cables in manholes, hand boxes and vent buildings
Water-proof and IP 68
