Already when designing the spreaders, extruders and ovens for the global baking industry, Haas-Meincke A/S is eager to incorporate Roxtec cable sealing solutions.
Roxtec seals keep dust out and prevent water from entering and damaging equipment during high pressure hosing. If compared to traditional cable glands, Roxtec products also make it easier to clean the machines.
"It is when the machines are running that our customers make money", says logistics coordinator Henrik Berg of Haas-Meincke A/S.
No more problems
Haas-Meincke A/S has developed the machines to ensure high reliability in production and a high level of hygiene. The previous solution using cable glands often gave rise to problems of hygiene due to the accumulation of debris. The Roxtec solution provides a smooth surface that is proof against moisture ingress even under high pressure hosing.
Reliable operation
Roxtec seals ensure that cable failures are less frequent, which helps avoid unnecessary machine downtime. If a cable should fail, replacement is quick and easy even if the cables are of different sizes and pre-terminated at both ends.
Financially good
"We consciously design our products to incorporate Roxtec seals right from the start. The advantage is we then have 100% integrated solutions for those machines for which there are stringent requirements for water-tightness and ease of cleaning – and, moreover, solutions that make very good financial sense," says Per Bjerrum, head of the design department.
- Keeps dust and water out
- Fits cables of different sizes
- Simplifies the cleaning process
- Withstands high pressure hosing
- Makes it easy to replace cables
Design and manufacturing of machines for the food industry in Skovlunde, Denmark
Producer
Haas-Meincke A/S
Sealing of cables entering equipment
Watertight and dust-tight
