  3. Roxtec presents new GRP sealing solutions for composite structures
  • Press release
Rectangular GRP frame
Roxtec GRP solutions are:
  • Type approved
  • Watertight
  • Gas-tight
  • A-class fire rated
Media contact
Ernes Music
Global Product Manager Department Global Products
